For practical purposes, no.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1436001-nzxt-cpu-cooler/#findComment-15429899
Anything is possible.
What I can tell you though is if you have to ask, you're not equipped to do this yourself.
Just build a DIY loop, AIO's aren't designed to be hacked up.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1436001-nzxt-cpu-cooler/#findComment-15429901
