Need help
Go to solution Solved by Guest,
38 minutes ago, Guest 5150 said:
I imported the video into an editor and slowed it down. This board has red underglow beneath that cover and you can just make out the red for a split second at half speed. I believe OP has a bad PSU or mobo.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1435115-need-help/#findComment-15423513
