For refernce my setup is as follows
MB: Asus ROG Strix B550-XE
CPU: Amd Ryzen 5 2600
Ram: 32gb Corsair LPX Vengence 3200mhz
GPU: AMD Radeon 5600
I accidntaly mad a big mistake, I bent some cpu pins and 1 of them broke of completley. The pin I lost was a AZ_BITCLK pin which from what I understand is a onboard audio pin so from my understanding it isn't causing the error. I am unsure as to what to do from here, I have ordered a new CPU but I do believe this one can be repaired.
2 hours ago, Guest 5150 said:
Pictures will say a million words.
What pin out picture did you look at?
I used this one: https://imgur.com/a/20BK1b1
The broken pin is located at AM,3.
I have gotten it to be stable for now, but only after I removed 1 set of my ram kits. I got the idea from another post which wasn't about a cpu issue at all but it helped me fix the problem, for now.
