GPU Cooler 4 Pin Plug Size Causing Problems
Go to solution Solved by Poinkachu,
3 minutes ago, cleric_warlock said:
I think that's a version of what I need, but i need to find something like that that goes from small male to big male. Tysm! I finally know what I'm looking for now.
Seen the bottom link yet ?
I've been trying to upgrade the fans on my gpu's built-in aio cooler and I've hit a snag, the 4 pin headers on the 3 way built-in splitter that power the stock fans are of a slightly smaller and maybe proprietary size, not only that, but the leads coming from the gpu wiring are female which means I would need some kind of male/male 4 pin extension connecter that had the smaller size on one end and the regular size on the other. Since I might be SOL on getting my gpu's built in cooling system to command all of its related fans through a fan hub using the pwm directly from my gpu's system, what other ways can I use to just as reliably tie my gpu temps to my gpu's fans? Since the gpu's built in splitter leads won't be connected to anything if I use an alternate solution, will I start getting system errors? This is the GPU system I've been working with https://pcpartpicker.com/product/mYYmP6/gigabyte-geforce-rtx-3090-ti-24-gb-aorus-xtreme-waterforce-video-card-gv-n309taorusx-w-24gd. Gigabyte doesn't even have this listed on their online support form and it's been impossible for me to get anyone from their tech support on the phone so far, so not expecting any help from them.
Current PC:
    • CPU
      AMD Ryzen 9 9950X3D
    • Motherboard
      MSI MEG X870E Godlike
    • RAM
      G.Skill Trident Z5 Neo 24GBx2 DDR5-8000 CL40-48-48-128 1.40v (F5-8000J4048G24GX2-TZ5N)
    • GPU
      Aorus Xtreme Waterforce RTX 3090 TI
    • Case
      Corsair 7000D Airflow
    • Storage
      (All NVME SSDs) 1 X Samsung 990 Pro (4TB), 2 x 2TB WD Black sn850, Sabrent Rocket 4TB
    • PSU
      Corsair AX1600i, Fully Modular, 80+ Titanium
    • Display(s)
      Alienware AW3423DW, Alienware AW3225QF
    • Cooling
      Arctic Liquid Freezer ii 420, Built in 360mm gpu rad, 7 x 140mm Noctua NF-A14's (4 used as full case fan set, 3 used to upgrade cpu rad fans), 4 x 120mm Noctua NF-F12's (3 used to upgrade gpu rad stock fans, 1 used to fill last remaining case fan slot)
    • Keyboard
      Custom Keychron Q6 Pro
    • Mouse
      Asus Rog Spatha X
    • Sound
      Senheiser Momentum 4
    • Operating System
      Windows 11 Pro
https://linustechtips.com/topic/1433093-gpu-cooler-4-pin-plug-size-causing-problems/
It's better if you take a pic of the said connector first
Refresh before you reply
https://imgur.com/a/DPwzXR3 here's an imgur link since i can't seem to get images to embed here
Current PC:
    • CPU
      AMD Ryzen 9 9950X3D
    • Motherboard
    • RAM
    • GPU
    • Case
    • Storage
    • PSU
    • Display(s)
    • Cooling
    • Keyboard
    • Mouse
      Asus Rog Spatha X
    • Sound
    • Operating System
      Windows 11 Pro
Soo standard extension?
https://www.newegg.com/p/1W7-005X-000C2
that's exactly what i already have and it doesn't work, the pins on the small female header are way too close together to fit in a standard 4 pin extension cable, the male end on the stock fans is also a lot more tiny and compact
Current PC:
    • CPU
      AMD Ryzen 9 9950X3D
    • Motherboard
    • RAM
    • GPU
    • Case
    • Storage
    • PSU
    • Display(s)
    • Cooling
    • Keyboard
    • Mouse
      Asus Rog Spatha X
    • Sound
    • Operating System
      Windows 11 Pro
Ahh, the pic isn't too clear on the smaller one since its taken from the front side.
Probably something like this then
https://www.dazmode.com/shop/watercooling/gpu-blocks/gpu-blocks-accessories/ek-cable-pwm-fan-adapter-for-gpu-50cm/
https://www.highflow.nl/aircooling/gpu-coolers/gpu-fan-pwm-adapter-cable-to-normal-4-pin-fan-header.html?sl=en
Current PC:
    • CPU
      AMD Ryzen 9 9950X3D
    • Motherboard
    • RAM
    • GPU
    • Case
    • Storage
    • PSU
    • Display(s)
    • Cooling
    • Keyboard
    • Mouse
      Asus Rog Spatha X
    • Sound
    • Operating System
      Windows 11 Pro
i can't read, thank you lol
Current PC:
    • CPU
      AMD Ryzen 9 9950X3D
    • Motherboard
    • RAM
    • GPU
    • Case
    • Storage
    • PSU
    • Display(s)
    • Cooling
    • Keyboard
    • Mouse
      Asus Rog Spatha X
    • Sound
    • Operating System
      Windows 11 Pro
Soo, that's what you need?
If so.
That's a JST-PH 4pin male (The small one), to KK254 female.
https://en.wikipedia.org/wiki/JST_connector
https://www.molex.com/molex/products/family/kk_254_rpc_connector_system
Care about the cable used for it, you need cable big enough to handle the amount of current your fans will use.
If so.
that second link from earlier was exactly what I needed, ty again
Current PC:
    • CPU
      AMD Ryzen 9 9950X3D
    • Motherboard
    • RAM
    • GPU
    • Case
    • Storage
    • PSU
    • Display(s)
    • Cooling
    • Keyboard
    • Mouse
      Asus Rog Spatha X
    • Sound
    • Operating System
      Windows 11 Pro
it's not even handling power current, it's just carrying a pwm signal to a hub
Current PC:
    • CPU
      AMD Ryzen 9 9950X3D
    • Motherboard
    • RAM
    • GPU
    • Case
    • Storage
    • PSU
    • Display(s)
    • Cooling
    • Keyboard
    • Mouse
      Asus Rog Spatha X
    • Sound
    • Operating System
      Windows 11 Pro
