I've been planning to build a PC and have a huge upgrade from my previous one , i now own a razer blade 15 GTX 1060 for the past 5 years or so, and prior to that one i had built a GTX 1070 PC.
I currently need help to find the best parts for me , i would consider my self a casual gamer who likes to play modern games, but i am also a working student in Communication and Media. So I'll need a PC around my budget , which can operate in both worlds, in gaming and editing.
Thank you
Budget (including currency): 20000mop
Country: Macau SAR
Games, programs or workloads that it will be used for: Elden Ring, Modern Games , movies , film editing, Photoshop , Illustrator, VR - Half Life Alyx
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Current monitor : ROG 32 inch 244 Hz curved . Parts : I'm looking to builder with Ryzen 9 5900x or equal , GPU RTX 3060 , 32 gb ram , AIO cooler , mother board (it was recommended to me ) ROG strix . ( These are the plans , the monitor is the only thing i have currently ) (sorry for the lack of detail )
Please do contact me either here or my email : dcngalves@gmail.com
Thank you for all your help
https://linustechtips.com/topic/1428294-need-help-building-a-new-pc/
Seems like 20k MOPs are worth approx 2.5K USD, with that you can easily build a 12700+3080 rig that will be much better than what you're expecting
I'm an AMD guy, but this is more or less a slightly revised version of my build, or what I would do today with a similar budget.
https://pcpartpicker.com/user/An0maly1976/saved/QTRgnQ
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
Thank you , but i believe the 12700 would be less for video editing and other creative softwares , it is true that it would work better , but i would believe it would be best for gaming
Sure, then you should choose between a 5950x and a 12900!
