Hello,
I'm planning my first build but I have a limit access because of cost of import (I live in Colombia). so I wanna ask if anyone could help me to make sense of my idea of build.
Thanks in advance
Ryzen 5 5600X
Asus Prime b550m-A ac
EVGA RTX 3050 8GB
SSD M.2 2280 GIGABYTE 256 GB NVMe3
Memoria Ram Xpg Gammix D30 8gbX2 DDR4 3200mhz
Fuente De Poder 750w 80+ Bronze Full Modular
Chasis Antec DP501 RGB ATX Black 1 FAN
https://linustechtips.com/topic/1426374-first-build-recomendations/
21 minutes ago, Delcas said:
Hello,
Thanks in advance
Ryzen 5 5600X
EVGA RTX 3050 8GB
5600x is overkill for a 3050 so i would recommend you to go for a radeon gpu like 6600 or 6600 xt(if you could stretch out the budget for it because it will preform MUUUUCH better than 3050
Dont cheap out on your storage, 256gb is going to run out very fast, my recommendation is: get a nvme m.2 like maybe 128gb for your boot drive (windows only, and maybe some apps that fit that you want to be faster) and then get a hdd 1tb bulk drive (any other stuff from your pc should go there)
and you are over spending on a power supply 300$ for a broze 750w psu is really a bad deal and i think you should actually be good with a 650w psu
and please change the case it has very bad airflow and your components will heat up really quick
a general tip: stick to well known brands because they arent well known for nothing
Okey okey.
I have seen an offer with the 5 5600 x
Radeon 6600xt or rtx 3060 ti 8gb
the same storage (for OS)
Same 16 RAM
Board B550M-K
a Corsair  Delta Chasis with Power supply cosair 650 80+ bronze.
This sounds better and closes to what you suggested
definetaly 3060 ti
Board B550M-K
If you are not going with aesthetics then this board should be good but if you plan on having it visible to you for most of the time it will look very odd to see a micro atx board in a full atx case (also im not sure if case actually supports micro mobo's)
Same 16 RAM
im sure you are aware of this but im going to mention it anyway, when you are putting in ram if you stick with this board occupy the 2nd and 4th slot from left to right, you can actually see the text a1 a2 b1 b2 with stars next to the slot name that should be occupied 1st)
For the rest of your build, should be good
