I had just built this PC yesterday, i have an i7 11700k and an RX 6600 XT. At a lot of point in my gameplay my fps seems to be limiting itself to as little as 30, 50, etc which doesnt make sense to me as i am able to get 350+ fps when it seems to be running smoothly. It might be some setting that i am not aware of any help and tips would be greatly appreciated.
https://linustechtips.com/topic/1424809-can-someone-help-with-my-fps-issues/
With that kind of setup, it does depend on what your gpu settings are at and what your game settings are at as well. I would try medium settings, play & see what happens. Then try high settings and see what happens. What does your build look like? Do you have a full build list?
Also, make sure on the cpu cooler that you're not using stock, as this could affect performance too. Dark Rock 4 and NH-U12S Redux are some good options.
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
