Building my first PC :)
Solved by Cr33ps,
Here is the different option, (30 dollars more but more performance)
https://au.pcpartpicker.com/list/nZyrrD
What is different:
1. 240mm aio, since the front panel is closed and you want and aio I just changed it to a 240mm one for exhaust because it is cheaper and is all you need.
2. 32gb of ddr4 3600mhz ram, better speeds for ryzen, more ram if you ever decide on streaming (16gb is totally fine)
3.Cheaper but amazing A tier psu
4.Matching fan with aio
It is 30 dollars more but it has better specs, if you do not like the price just get a 2x8gb kit of ddr4 3600mhz ram
