Hi Guys.
I have this code that will delete all my backup file in my NAS which are older than x days
I am running this code directly from powershell and its works fine
But my goal is to have this task run from task scheduler via the "ps1" file but it just not working
Double click on this ps1 also not working
I have change my ps1 script to always open with powershell, also set ecexution policy to unresricted (not really sure what this does anyway)
here is my script
Get-ChildItem -Path "Y:\SM Backup\DB Backup" -File -Recurse -Force | Where-Object {($_.LastWriteTime -lt (Get-Date).AddDays(-5))}| Remove-Item  -Force
Can anyone help?
Thank you
https://linustechtips.com/topic/1421862-need-help-with-powershell-ps1-file/
Powershell scripts need to be run by right clicking and "run with powershell".
To run them via task scheduler, in actions, set it to run powershell.exe and then in "Add arguments" type the below:
-f "C:\Scripts\MyPSScript.ps1"
Obviously, replacing that path with the one to your ps1 file.
Problem is even double click on my ps1 file doesnt delete my backup, the powershell  window launch for a few second and just disappear and it doesnt seem to do anything
Add a line at the end with "pause" written. Will stop it from closing so you can see any errors
