Budget (including currency):  around 1300-1500 CAD
Country: Canada
Games, programs or workloads that it will be used for: Minecraft, Microsoft Teams, Fortnite, Possibly Call of duty.
Other details Only Part I have On me at now Is A Gigabyte RTX 3050 Gaming OC 8GB card with 3 fans, here is a list of parts I think would work great if there’s any issues please lmk and also if anyone knows how to add RGB cables from the power supply to the GPU or any rgb cables please help.
https://ca.pcpartpicker.com/list/Q93K4s
https://linustechtips.com/topic/1421820-help-building-first-pc/
Country: Canada
why getting a 3600x when you can get a 5600x for a little more?
and a better board
also you forgot to put an SSD
here is a new list
you also dont need to buy windows
and 850 w power supply is too much
also i changed the ram to a better kit
https://ca.pcpartpicker.com/list/N9j3tn
https://linustechtips.com/topic/1421820-help-building-first-pc/#findComment-15330876
and a better board
here is a new list
https://ca.pcpartpicker.com/list/ZVtcqm
also for RGB you can just plug them to the motherboard or if you have a lot of them you can buy an RGB/fan hub
the case will likely come with a fan hub preinstall
they will either connect with Molex or sata to the PSU
https://linustechtips.com/topic/1421820-help-building-first-pc/#findComment-15330894
Country: Canada
https://linustechtips.com/topic/1421820-help-building-first-pc/#findComment-15330903
Country: Canada
one thing i forgot
the board will probably support your cpu out of the box but if it doesn't
you need to flash the latest bios on it
don't worry
you can do it without installing anything on the board
here is a video that will help you
https://linustechtips.com/topic/1421820-help-building-first-pc/#findComment-15330908
