I'm pretty sure the card would not physically fit. The Windforce OC is a dual-slot card, and there isn't another slot in the back below that one, so you won't be able to properly slot it in place. Plus, I'm pretty sure it would impact the power supply even if you removed the PSU shroud.
https://linustechtips.com/topic/1421570-air-clearance/#findComment-15329176
