Hey guys,
I got a adata su800 512GB SSD.This is about 1 year old. I bought the ssd as a replacement of my broken hard drive of my laptop. Now I decided to use the SSD in my desktop. And after clean installation of windows 10 I ran crystal disk mark to compare my ADATA SU800 SSD with CRUCIAL BX500. I found that my ADATA SU800 is giving me very low read/write speed abt 200MB/s. I tweak some of bios setting and the speed improved to 400MB/s but still not the advertised speed.  What can i do to get the full speed out of my SSD.1834504434_Screenshot(3).thumb.png.95646e4314c6883887e8dd18d0ca5500.png
MY PC SPECIFICATION:-
i5-3470s
8GB DDR3 (Corsair)
ASRock- H61/U3S3
GT-710
ADATA SU800
500W PSU (ANT ESPORTS)
https://linustechtips.com/topic/1420861-adata-su800-slow-speed/
SU800 is not a fast SSD, especially if the pSLC buffer is used up (but it's still better than most other SSD out there). But well the reads should be still good.
The benchmark shows SU800?
What did you tweak in BIOS?
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + Thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + PLX88024 PCIe switch (PCIE 4.0 x8 -> 4 x M.2 PCIe 4.0 x4) -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD : LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + flexiDOCK MB014SP-B + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aiyima A80 ( or Aune S6 Pro -> RCA ->  Aiyima A80 ) -> Polk S20e black -> Monoprice stand 16250
HEADPHONES : PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + Kensington VeriMark / PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Razer Wolverine V3 Tournament Edition 8K PC (B0F94C9C43) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox series x controller pc (1VA-00002) + Ravcore Javelin
NET :  Intel E810-XXVDA2 2 x 25GbE SFP28 (PCIE 4.0 x8) -> 2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3) -> Qnap TS-932X-2G + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB -> 2 x FTLX8571D3BCV-IT -> Noctua NF-P14s redux 1200 PWM -> QNAP TR-004
https://linustechtips.com/topic/1420861-adata-su800-slow-speed/#findComment-15324553
IDE TO AHCIIMG_20220330_173117.thumb.jpg.6ba6315498e086a1b6be03519119bfb3.jpg
https://linustechtips.com/topic/1420861-adata-su800-slow-speed/#findComment-15328634
The culprit here is the ASM1061 SATA III controller, that is connected to chipset with only PCIe Gen2 ×1
So no way to go around it, without sacrificing the GPU slot, on some external multi PCIe lanes SATA controller. that is not worth the investment, and would leave you without the GPU.
You need to buy the current generation mobo and cpu
EXTERNAL
HDD/SSD :
https://linustechtips.com/topic/1420861-adata-su800-slow-speed/#findComment-15333477
I found this in by BIOS
https://linustechtips.com/topic/1420861-adata-su800-slow-speed/#findComment-15339422
  • 2 weeks later...
First of all, that setting only changes the PCIe gen on PCIE 1
The real problem is that the controller ASM1061 only has PCIe Gen2 ×1, like even if you had it as external, and plug it to PCIe3.0, it would still be runing max on PCIe Gen2 ×1.
EXTERNAL
HDD/SSD :
https://linustechtips.com/topic/1420861-adata-su800-slow-speed/#findComment-15354002
