Please help! I need help ASAP
Go to solution Solved by tkitch,
that'll do exactly what you need, just remember all the ports will be sharing bandwidth.
The issue I’m having is that I got a new case for my Gaming PC, a ASUS ROG Helios. My mother board is a Asus ROG Strix Xi Maximus Hero Intel Z390 Chipset. The issue I’m having is there is only 1 USB 3.1 Gen 1 input on my Mother board and I need 2 for the front panel of my Asus ROG Helios. I’ve tried to find a device to fix this but tbh I’m lost! Can anyone please give me suggestions on what I can buy to split or produce more internal USB 3,1 Gen 1 connections (20 pin connector). Thanks in advance!
https://linustechtips.com/topic/1420769-please-help-i-need-help-asap/
