After a few months of use some of my keycaps paint is starting to wear off, from what I saw from another post was that its a slight variation of the Kalith low profile Choc switches. I dont have experience with these unique mounting styles of these switches so I wanted to get some help with this. If I buy or 3d print the Kalith low profile chock switches do i need to do anything else to allow them to fit within my logitech g915?
https://linustechtips.com/topic/1417988-g915-tkl-replacement-keycaps/
6 hours ago, James Evens said:
Since it is a few months old utilize the Logitech warranty.
There are some key caps available in china but only for US-layout.
In the end I had to resolve to 3D-printed keycaps: https://www.prusaprinters.org/prints/96563-compatible-logitech-gl-g815-g915-keycap
Yeah issue is that it was a christmas gift and i dont think 3 starting to wear off keycaps are worth submitting a warranty ticket. Thanks for the 3D files will try that as soon as I get access to a resin 3d printer.
