I have a computer with a 3070 Ti, 5800X and 750W PSU, I was doing some design on fusion 360 when “BANG!” I saw a white flash and the pc shut down. The GPU looks to be fine and the mobo looks like no blown capacitors but the PSU seems like it’s cooked. I then threw in another PSU to test and the motherboard lit up when power switch was turned on but then that PSU fried too. Anybody know what my problem could be?
https://linustechtips.com/topic/1417955-help-2-psus-fried/
What PSUs? There's many 750W PSUs. EVGA Gold isn't a model either. G2 is, Corsair RM750x is a model number etc.
When the first one died, you didn't reuse any of the cables from the old one did you?
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1417955-help-2-psus-fried/#findComment-15303510
were the PSUs the same model? If not, did you swap the cables as cables are NOT compatible between brands and even models within a brand.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1417955-help-2-psus-fried/#findComment-15303511
