Hi all,
So I have an issue that I hope you can help me with.
I have a smartphone that is connected to an wireless access point. When I ping from the Access Point(AP) > smartphone, I experience high and inconsistent ping times compared to when I ping from the Access Point > a non-smartphone device(e.g Linux laptop) which gives low and consistent ping times. I have tested this with different routers, as well as a different brand of router, and different Android smartphone devices but I still am left with the same problem. This has also occurred with other Access Points in a different location.
To add, if I ping the smartphone > Access Point, the ping times are normal(low and consistent).
I have attached two screenshots:
  1. Ping times from AP > Smartphone
  2. Ping times from AP > Laptop.
I would greatly appreciate any information regarding the high & inconsistent ping times from the AP > smartphone. Does anyone know if this is a hardware, software or Android network priority issue?
