2 minutes ago, AmirAcle said:
should both be uncheck ?
To do what you asked, you'd need "When I speak" checked. Then you'd need to adjust the slider based on the description to fit your needs.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1415156-audio-question/#findComment-15284333
