Too many cables...?
Go to solution Solved by drdrewnatic,
12 minutes ago, NewwGuyy123 said:
Thank you.
So just to recap - for black and white fan connectors, I should connect the black one into any 4-pin slot on my mobo and ignore the white one, correct?
And for the Gigabyte vs Asus / Asrock / MSI one, I should use the Asus / Asrock / MSI cable end even though my mobo is Gigabyte, and connect it to a slot near the top right or bottom left of the mobo that has the configuration "pin, pin, nothing, pin", correct?
Yes. That proprietary Gigabyte connector is only found on some Gigabyte motherboards but not others. It appears yours doesn't have it but does feature the 4-1 (pin, pin, nothing, pin) DRGB connector. What you want to plug that into is the D_RGB connectors located at the top right and bottom left next to the audio connector on your motherboard.
As for the fans, technically if you really wanted to plug it into your commander core, you could, but I wouldn't recommend doing that as many fan controllers are only designed to have one fan plugged into each port. It's the same reason why you wouldn't plug a power-bar into another power-bar. I would probably plug it into a standard system fan connector, not a system fan pump connector. Now, I don't have a Gigabyte motherboard myself, but on my ASUS board, my pump headers run at 100% all the time and can't be changed. I think that that is just an issue with ASUS boards and I haven't heard of any other motherboard manufacturers do that but better safe than sorry.
Good luck with the rest of your build!
I'm building my first PC and I've come across a few cables that I'm not able to identify and I have no idea where they're supposed to go. Pictures below:
1) these two connectors coming from the same cable, which comes from my front panel (I've already connected the front two fans and start button, so dk what these could be?). My case is Cooler Master H500M Mesh (https://www.coolermaster.com/catalog/cases/mid-tower/mastercase-h500m/)
2) This SATA (?) cable coming from the "commander core" of my AIO cooler (Corsair iCUE H150i Elite Capellix (https://www.corsair.com/us/en/Categories/Products/Liquid-Cooling/iCUE-ELITE-CAPELLIX-Liquid-CPU-Cooler/p/CW-9060048-WW)). I'm using just a single SSD (the Samsung 980 pro 2tb (https://www.samsung.com/uk/memory-storage/nvme-ssd/980-pro-2tb-nvme-pcie-gen-4-mz-v8p2t0bw/)) so do I even need a SATA cable for anything?
Commander Core
3) these two connectors coming from the same cable, the top one has a sticker marked Gigabyte, while the bottom one says Asus / Asrock / MSI (my mobo is Gigabyte X570 Aorus Master). The cable comes from what one Youtuber called a "fan hub" at the back of my case (Cooler Master H500M Mesh - link above), but I can't figure out where to plug it in.
Appreciate any input!
https://linustechtips.com/topic/1414887-too-many-cables/
43 minutes ago, Caroline said:
First pair is for a fan, they should click together.
If I click them together the cable will literally be going into itself, see below:
47 minutes ago, Caroline said:
The last 2 look like they're for LEDs, I might be wrong but they should go into your motherboard, read the manual to find which one you should plug in.
Since my mobo is Gigabyte I assume the one labeled Gigabyte is the one I should plug in, I just dk where since it has such a weird connector (the one with exactly 3 holes in it)
https://linustechtips.com/topic/1414887-too-many-cables/#findComment-15282559
That 3 pin only connector is a VDG cable. Apparently Gigabyte in their infinite wisdom decided to create a different 3 pin connector instead of the standard 4-1 pin 5V ARGB used by every other brand for some of their motherboards. Looking at the manual for yours, it appears that you don't have this proprietary connector and instead have the normal 4-1 pin connector. I'd assume that Cooler Master put both connectors their to maintain compatibility with all motherboards and you should be just fine to use the 4-1 connector. Looking at the manual, their should be one at the top right of the motherboard and bottom left next to the audio connector.
Due to my inability to think before I type, I frequently edit my posts. Please refresh before responding!
Tag me @drdrewnatic or quote me so I can see your response.
______________________________________________________________________________________________________________
CPU: INTEL CORE I5-12600K GPU: ASUS ROG STRIX GEFORCE RTX 2070 OC MB: GIGABYTE B660 AORUS MASTER DDR4 RAM: 2X8GB G.SKILL TRIDENT Z RGB 3200 CL16 BOOT: CRUCIAL P5 PLUS 1TB SSD: SAMSUNG 860 EVO 500GB HDD: SEAGATE 2TB 7200RPM PSU: EVGA G3 650W COOLER: THERMALRIGHT PEERLESS ASSASSIN 120 SE ARGO
01101100 01110100 01110100 01110011 01110100 01101111 01110010 01100101 00101110 01100011 01101111 01101101
https://linustechtips.com/topic/1414887-too-many-cables/#findComment-15282651
Sorry, which of my pictures are you referring to, the one coming from the case's front panel (with the white and black connectors) or this other one with Gigabyte vs Asus / Asrock / MSI?
https://linustechtips.com/topic/1414887-too-many-cables/#findComment-15282687
Gigabyte vs Asus / Asrock / MSI. Sorry, guess I should of made that more clear. @Caroline answered about the white and black connectors being fan connectors. To elaborate more on that, the black connector is a 3-pin DC fan connector however, 3-pin fan connectors can be plugged into 4-pin connectors as that last pin is not necessary. Assuming this cable is coming from the case's built in fan controller, I would just plug it into a motherboard fan header. Just make sure that you are lining up the notch with the grove to make sure that you are plugging it in the write way.
Now unlike plugging a fan into the commander core, if you want to change the fan curve for those two front intakes, you'll have to do it on the BIOS instead of a third-party application like Corsair iCue.
https://linustechtips.com/topic/1414887-too-many-cables/#findComment-15282702
Thank you.
https://linustechtips.com/topic/1414887-too-many-cables/#findComment-15282716
Thank you.
https://linustechtips.com/topic/1414887-too-many-cables/#findComment-15282763
