Budget (including currency): < 6,000$ USD
Country: USA
Games, programs or workloads that it will be used for: VR and Gaming (Roblox/Minecraft)
looking to spend quite a bit on a high-end gaming pc. I put together a general parts list, I know I want a i9 12900k, a evga 3090 kingpin and ddr5 memory but im not quite sure on the motherboard, the cpu cooler and case. if i could get some recomendations that would be epic, thanks
PCPartPicker Part List: https://pcpartpicker.com/list/KmznQ6
CPU: Intel Core i9-12900K 3.2 GHz 16-Core Processor ($613.97 @ Newegg)
CPU Cooler: Corsair iCUE H150i ELITE LCD 58.1 CFM Liquid CPU Cooler ($289.99 @ Best Buy)
Motherboard: Gigabyte Z690 AORUS PRO ATX LGA1700 Motherboard ($319.99 @ Amazon)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-5600 CL36 Memory ($349.99 @ Corsair)
Storage: Samsung 980 Pro 2 TB M.2-2280 NVME Solid State Drive ($279.99 @ Amazon)
Video Card: EVGA GeForce RTX 3090 24 GB K|NGP|N HYBRID GAMING Video Card
Power Supply: SeaSonic PRIME Ultra Titanium 1000 W 80+ Titanium Certified Fully Modular ATX Power Supply ($299.99 @ B&H)
Total: $2433.91
Generated by PCPartPicker 2022-02-17 17:37 EST-0500
https://linustechtips.com/topic/1412544-high-budget-pc-help-case-optimization/
Country: USA
looking to spend quite a bit on a high-end gaming pc. I put together a general parts list, I know I want a i9 12900k, a evga 3090 kingpin and ddr6 memory but im not quite sure on the motherboard, the cpu cooler, power supply or case. if i could get some recomendations that would be epic, thanks
PCPartPicker Part List: https://pcpartpicker.com/list/sm6cfv
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($46.99 @ Amazon)
Total: $1900.92
Generated by PCPartPicker 2022-02-17 13:14 EST-0500
For a power supply I would go with a seasonic prime ultra 1000w eaisly one of if not the best power supplies.
Gigabyte z690 motherboards have had memory issues reported.
The build is missing a case and PSU.
Why an HDD? Given the budget, why not a second 2TB NVMe drive
You might want to fix the OP ddr6 typo. It should read DDR5.
Not a fan of the cpu cooler unless a bling overload is desired.
Thanks for telling me about the typo, I edited the parts list to include the psu that someone recommended and another nvme. Do you have any recommendations for a better/more reliable motherboard?
I think it would better to stick with DDR4 unless you have a specific use case that needs high speed RAM. We're probably 1-2 years out before DDR5 makes sense for most people.
Titanium PSU is unnecessary, but eh you have the budget.
Recommended build:
Motherboard: MSI PRO Z690-A DDR4 ATX LGA1700 Motherboard  ($219.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 64 GB (4 x 16 GB) DDR4-3200 CL16 Memory  ($239.99 @ Newegg)
Case: Corsair 5000D AIRFLOW ATX Mid Tower Case  ($139.99 @ Newegg)
Power Supply: EVGA SuperNOVA G6 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  ($152.98 @ Newegg)
Total: $2216.89
Generated by PCPartPicker 2022-02-17 18:17 EST-0500
You might consider the MSI Z690 Tomahawk.
Hi Blu
Just out of curiosity... will you not need to be signed up in order to get access to the EVGA Kingpin 3090 GPU?
I've had good experience with Asus 3090 Strix, if you would be considering alternatives down the road.
I concur with the others, suggesting going with a DDR4 MoBo, but if you insist, the choice of RAM looks OK, to me.
DDR4 -> MSI PRO
DDR5 -> I'm biased, as I like Gigabyte, but i guess there are cheaper and equally/better performing alternatives. Just completed some silly builds with Giga Xtreme MoBo's, as i could not get a hold of the Giga Aero D.
As for CPU cooler, I've had really good experience with Arctic Freezer II 420mm in push/pull config, paired with the 12900K. Just remember to get the LGA1700 kit, if not included. If you are totally into an "Extreme Glitter-Bling-Box of Doom", then stick to the Corsair, and switch the fans on the Kingpin, as well.
Case... I've been a bit of a Phanteks "Phan"-boy, as they have good quality and intuitive design(while building), so a P500A could be an alternative to the suggested Cor 5000D.
Good luck with you build! 🙂
BR. DD
