I assume you mean a wireless broadband router or modem, given its PoE.  In which case its only limited by the length of ethernet cable, 100m max, possibly a little less as there may be losses from the injector.  That would include the length both before and after the injector combined though.
CAT 6 would be fine, but if any part of it is outdoors it needs to be outdoor rated so that sun and weather doesn't degrade the cable.
