Budget (including currency): £1500
Country: United Kingdom
Games, programs or workloads that it will be used for: CSGO,HOI4,EU4,VISUAL STUDIO, CYBERPUNK (general gaming triple A and others)
Other details 60-100+ frames for most games, 144hz monitor, will be first PC I will own and built myself.
https://uk.pcpartpicker.com/list/mKDRBj
Hello LTT forum,
In the coming days I will be looking at ordering the partS for my first PC build.
I have a rough idea on what I need and what seems to be good, but I am still very much learning.
In the link I have posted the parts I think will work for me and any suggestions from you would be very helpful.
The main source of confusion for me is choosing the right motherboard and what features should I really be looking for.
For example, I have a build note from PCPP "The be quiet! Pure Rock 2 Black CPU Cooler may require a separately available mounting adapter to fit the MSI MAG Z690 TOMAHAWK WIFI DDR4 ATX LGA1700 Motherboard."
I am not entirely sure how I would get around this, from my understanding the mounting adapter fits to the bottom of the MOBO?
Any tips or products I need to look for?
Due to graphics card shortage I haven't included one, I was hoping for 3060TI but I do not think is likely, what is a 300-500 pound graphics that would be worthwhile and synergise with my build?
Thanks
SBRQW
https://linustechtips.com/topic/1411553-my-first-build/
3 minutes ago, StalePie42 said:
are you sure that you cant get a 3060 or a 3060ti i mean you still have around £650 to spend
You might be right actually.
I think I was a little generous with the budget, i was thinking of 1500 as the ceiling.
I think it just makes me wince shelling out 600-700 on a gpu and just wondered if there were any alternatives.
Thanks for your reponse.
https://linustechtips.com/topic/1411553-my-first-build/#findComment-15259407
Something like this might work
https://linustechtips.com/topic/1411553-my-first-build/#findComment-15259411
so what is the ideal amount you would like to spend
https://linustechtips.com/topic/1411553-my-first-build/#findComment-15259553
Hello LTT forum,
Thanks
SBRQW
for mobo you honestly dont need anything special unless your overclocking just getting built in wifi is good
https://linustechtips.com/topic/1411553-my-first-build/#findComment-15259726
https://uk.pcpartpicker.com/list/fsWhMb
Wasn't sure if you needed the WIFI part. If not, you can go for a Ryzen 5 5600X and a B550 Tomahawk. The 2 140mm fans are for the front of the case (intake).
Am I still to create the perfect system?! ~ Clu
Keep your expectations low, boy, and you will never be disappointed. ~ Kratos
https://linustechtips.com/topic/1411553-my-first-build/#findComment-15259808
Thanks for you reply.
I was wondering this, would the two extra fans be optimal for this build?
I think the case has one in the back and one in the front, is that not enough?
https://linustechtips.com/topic/1411553-my-first-build/#findComment-15259957
You can hold off on getting them for now, but I would recommend them for better airflow. If you prefer, I would recommend at least one more at the front (intake) or one more for the top-rear of the case (exhaust). That would just help the airflow better.
https://uk.pcpartpicker.com/list/zXZVnt
https://linustechtips.com/topic/1411553-my-first-build/#findComment-15262198
