Budget (including currency): 1.5k for pc CAD
Country: Canada
Games, programs or workloads that it will be used for: 4k Gaming and 1080p (Forza 5, Minecraft, 4k & 1080p streaming, live streaming, torrenting (don't do it, i don't encourage it), general gaming ( mostly AAA & AA games)
Have a monitor (all in one)
Keyboard & mouse
The amazon list (scroll down to find pc)
https://www.amazon.ca/hz/wishlist/ls/33ORDG3IQAV9?ref_=wl_share
Total value of everything combined is around 2.5-6k Canadian Dollar
2.6k CAD
2k USD
The pc it self:
https://www.amazon.ca/dp/B09DHTWR5N/?coliid=I3G344S8Q2Z97&colid=33ORDG3IQAV9&psc=1&ref_=lv_ov_lig_dp_it
 i5-11600KF 3.9GHz,
16GB DDR4,
GeForce RTX 3060 12GB
Thank you (:
https://linustechtips.com/topic/1411127-15k-pre-built/
You should be able to get 3060ti and i5-12600 for $1500cad - looking at USD
Even that won't be giving you 4k high graphics setting outside older games but 1080p and 1440p should be no problem. DLSS will be your best friend for 4k
That case is trash and the psu that comes with it is a fire waiting to happen.
The best gaming PC is the PC you like to game on, how you like to game on it
https://linustechtips.com/topic/1411127-15k-pre-built/#findComment-15256720
19 minutes ago, IPADboi said:
Where exactly? I cant find anything for that price. Is this before or after GPU shortage??
I was looking at USD >.<'
you can get laptops for that price and save on the webcam and holds a higher resale value than a prebuilt desktop
https://www.dell.com/en-ca/shop/dell-laptops/g15-gaming-laptop/spd/g-series-15-5511-laptop/ng155511_sb_h27pe
https://linustechtips.com/topic/1411127-15k-pre-built/#findComment-15256759
I was thinking about a laptop, but saw many videos saying not to get one...
Will it still be able to run games and get good fps?
also dont laptop gets super hot and noisey?
https://linustechtips.com/topic/1411127-15k-pre-built/#findComment-15256771
They can if the laptop can't get fresh air, keeping the laptop base off the desk helps this a ton. You are going to run into the same problem with a restricted airflow case
this  has the same style of case, gamers nexus has a ton of these prebuilt desktop reviews and so far none have stood up to scrutiny.
This is a decent option https://nzxt.com/product/h1-mini-pc
https://linustechtips.com/topic/1411127-15k-pre-built/#findComment-15256788
I was  lookin and found these:
https://www.dell.com/en-ca/shop/dell-laptops/g15-gaming-laptop/spd/g-series-15-5511-laptop/ng155511_sb_h2801pe
Laptop^
https://www.dell.com/en-ca/shop/dell-laptops/alienware-m15-r6-gaming-laptop/spd/alienware-m15-r6-laptop/naam15r6_s11e
Laptop ^
https://www.dell.com/en-ca/shop/desktops/xps-special-edition-desktop/spd/xps-8940-desktop/dxps8940ser_s522e
Pc ^
https://linustechtips.com/topic/1411127-15k-pre-built/#findComment-15256796
That xps desktop is the worst reviewed desktop I have ever seen. It's around 40-60% the performance of the listed parts.
G15 laptops are really nice, it's thicker than the Alienware but they added cooling to match the size.
Out of the 3, the g15 would be my choice.
https://linustechtips.com/topic/1411127-15k-pre-built/#findComment-15256813
 Thanks for the help!
https://linustechtips.com/topic/1411127-15k-pre-built/#findComment-15256822
went looking again and found Skytech https://skytechgaming.com/product/archangel-3-0-intel-core-i5-10400f-nvidia-geforce-rtx-12gb-1tb-ssd-16gb-ram/
good case, great fans, and a decent parts list for the price.
https://linustechtips.com/topic/1411127-15k-pre-built/#findComment-15258394
