Questions regarding thermal paste...
24 minutes ago, RTXboy123 said:1) Why is thermal paste required?
To fill in the tiny inconsistencies / gaps in the surfaces of the heatsink / CPU IHS. These surfaces aren't perfectly flat, so you need something to fill in these spaces to allow for better thermal conductivity.
24 minutes ago, RTXboy123 said:2) You don't cover the whole processor IHS with thermal paste, just a little dot in the center, why? But then you cover the whole GPU die with the thermal paste.
I do cover the hole IHS. I spread the paste? CPUs generally have more mounting pressure and will spread the paste even if you don't. Also with a GPU it's critical to get the paste coverage everywhere as just part of a GPU can die. Not all of a CPU "needs" covered, although if it is better if it is covered.
24 minutes ago, RTXboy123 said:3) Doesn't the processor IHS result in a penalty in heat transfer? Just like in graphics cards, we can integrate the cooler with the processor to completely remove the IHS and give direct cooling.
Yes as it's another layer between things. Hence why delidding is a thing. There are also heatsinks meant for "naked" CPUs. However it's also much easier to damage a CPU without a IHS.
24 minutes ago, RTXboy123 said:4) Why don't we just use liquid metal more often than thermal paste? It is way cooler.
The amount of work and maintenance it creates. The cleanup involved. Liquid metal isn't exactly straight forward to apply to get the best results. Incompatibility with some coolers? Have you used liquid metal before? Here is one of my delidded CPUs, notice the scarring / marking of the CPU die, that's after only a week:
