I was doing some driver updates yesterday on a trusted website “bit driver updater” as soon as I updated everything (5 things) I uninstalled the app, as soon as I did this my pc started being reallllllly laggy, even in normal use, I check task manager and my 1tb m.2 isn’t showing up, it’s not showing in device or disk management either but does actually show up in my BIOS. I just don’t know how to fix it and if it’s fixable!!
my build
Mobo: Msi x570 prestige creation
CPU: Ryzen 7 3700x (water cooled)
GPU: aorus 1070ti 8gb
RAM: 32gb 3600mhz Corsair vengeance rgb pro
PSU: EVGA 850 bronze
Storage:500gb HDD, 500gb SSD, 1tb nvme m.2
https://linustechtips.com/topic/1409483-need-help-guys/
3 minutes ago, Pixelfie said:
Do you have a system restore point? If not I think you could reinstall Windows without losing stuff somewhere in settings.
This is one of the reasons I would never recommend driver update tools.
I’ll try a fresh install of windows today, i realised after going on disk management that you can just update them on there, I’ll do a fresh install and will come back! Thank you
https://linustechtips.com/topic/1409483-need-help-guys/#findComment-15245210
