Greetings, members.
I need your help. I use a 2200 VA Pure Sine Wave inverter having an output wattage of 1760 Watts with two batteries (220 Ah each), but while gaming, if there is power, my pc RESTARTS. However, everything works as expected if the computer is idle or performing some not so power-hungry task on a power cut. Plus, after RESTARTS, if I play the same game on the exact configuration on the inverter, there is no issue.
The total calculated power consumption of the room where the computer is installed does not exceed 1000 Watts. I googled a lot but got nothing useful. Got my PSU checked. After a few tests, the Service centre guy told me it's working fine.
I have the following hardware:
1)  Asus 3090 Oc gaming GC
2)  Corsair AX1000 80+ PSU
3)  AMD 5950x
4)  3 NVME SSD’s
5)  1 HDD
6)  Benq 32 inch Monitor
Please guide.
Thank you.
https://linustechtips.com/topic/1407174-please-guide-need-your-help/
