Hi guys, so I have a Lian Li Galahad 360 AIO I installed. It works great, but I want to run everything to my motherboard. The fans that come with it are SL's I believe.
On top of that, I bought the Lian Li Unifans AL and both the the 24 pin, and the 3-8 pin Strimer Plus RGB extensions.
My initial thought was that I should get a RGB/Fan hub to link everything together, but the plugins make for a difficult task and has driven me crazy.
The SL fans come with both an ARGB and PWM cable for each fan. The PWM connects just fine, but the ARGB doesn't due to wings on the side of them.
I also bought an ARGB cable kit that Lian Li sold for extra cables in case but that still doesn't seem to fix my issue. As mentioned, my end goal is to **run everything to the motherboard for RGB software control**. If anyone has more insight on this, it would be greatly appreciated!
List of Parts:
Cooler Master ARGB/PWM Fan Hub
Lian Li Galahad 360 AIO w/SL Fans
Lian Li Strimer Plus 24-pin w/ controller
Lian Li Strimer Plus 3-8 Pin GPU Extension w/ controller
Lian Li Unifan AL 120 3-pack w/ controller
Extra Lian Li ARGB cables
MSI MPG X570 Gaming Edge Wifi Motherboard
https://linustechtips.com/topic/1403409-lian-li-argbfans-setup-help/
