I recently got a new gaming computer. Paid 1400 euros for it, and now I wanna get the best performance out of it.. but I don't know what to do.. or from where to start.. or the stuff that I need to do. My pc is all AMD, CPU is AMD Ryzen 5 3600, on a aorus elite a520 f13g motherboard, which is liquid cooled from master cooler, the lite version, 16 GB of ddr4 ram, clocked up to 3200 mhz from g.skill ripjaws and rx 6600 xt pro from gigabyte.
If someone can help me out.. with every setting that I need to do on the motherboard itself, and the amd app for oc,
The case is also from megaport hunter, with 4 fans, and I have 1 tb of crucial ssd.
Anyone that can help me with the best oc settings for this setup. God bless ya and thank you for anyone who will try in the future to help me out. Love y'all
https://linustechtips.com/topic/1398950-hello-i-need-some-help/
If you're unfamiliar with computers as a whole I wouldn't really go messing around in the bios trying to OC the cpu. Newer AMD chips have PBO on them, which is basically an "auto overclock" if you will.
Ryzen 9 5900x | ROG Crosshair VIII Dark Hero | RTX 3080 FTW3 Ultra | H150i Elite | T-Force XTREEM 3600mhz CL14Corsair 5000D Airflow
https://linustechtips.com/topic/1398950-hello-i-need-some-help/#findComment-15174167
Agree with the post above, don't go tinkering about in the BIOS if you have no idea what half of the things do and aren't familiar enough. However, I would suggest checking this GN video for more info on PBO, along with where you would look to enable it safely if you want to make sure it's on, or want to turn it on. Around 11 minutes in you can see Steve in Ryzen Master, as well as the BIOS showing how to enable it. I just wouldn't tinker with the PPT, TDC, or EDC values whatsoever, nor any of the values that appear if you select manual. If it isn't set to enable, set it to that, and leave it be. Not sure how much, if any improvement you'll really see but it's something you can safely do. It took me a bit of tinkering with my R7 3700x to dial in a precise PBO boost and I wouldn't recommend it for anyone not comfortable. You should find the option to enable PBO through the AMD CBS menu within your BIOS.
System Specs: (Click Expand)
          "Beatrix"
  • CPU AMD Ryzen 7 5800x3D
  • Motherboard GIGABYTE X570 I AORUS Pro Wi-Fi
  • RAM 2 x 16GB Corsair Vengeance RGB Pro @ 3200mhz CL16
  • GPU Gigabyte Eagle RX 6700XT
  • Case Corsair Crystal 280x
  • Storage 1x Samsung 980 Pro (1TB) 1x Samsung 970 Evo Plus (500GB) 1x Samsung 860 Evo (1TB)
  • PSU EVGA G5 850W
  • Display(s) 32" Odyssey Neo G7 & 27" Viewsonic XG2705
  • Cooling Corsair H100i Elite Capellix AIO | 4x QL120 RGB fans | 2x QL140 RGB fans
  • Keyboard Logitech G Pro
  • Mouse Logitech G502 Lightspeed /w Powerplay
  • Sound Logitech G Pro Wired
  • Operating System Windows 11 Professional 23H2
https://linustechtips.com/topic/1398950-hello-i-need-some-help/#findComment-15174233
