So ive got a Question what is the max Safe Voltage on these Dram Chips (BLS8G4D30AESBK.M8FE). Ive been running my 32 GB kit at 1.4 Volt. Is that Safe?
Ryzen 7 3700x with pins Soldered Back on it.                         80€
Asus ROG Strix X570 E Gaming + 32GB Ballistix Sport Ram  300€
Sandisk Extreme Pro 1TB                                                       80€
RTX 2060 Super        250€
Samsung 870 QVO 1 TB                                                        70€
https://linustechtips.com/topic/1398183-micron-ram-max-voltage/
Should be..
I have never seen anyone scrub the serial from CPUZ, most impressive.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1398183-micron-ram-max-voltage/#findComment-15169362
4 hours ago, freeagent said:
Should be..
Its pretty Easy to Do. But what is the max safe Voltage ive seen some say 1.4 some 1.45 some 1.5. My RAM is at 3800Mhz but I want to tighten the Timings.
RTX 2060 Super        250€
https://linustechtips.com/topic/1398183-micron-ram-max-voltage/#findComment-15169662
I know, I have seen thousands of CPUZ shots 😄
I would say somewhere between 1.4 and 1.45, so 1.435v 😄
I cant answer that with certainty, the only type of DDR4 I have ever owned is B-Die. I have seen what others recommend, but cannot say for sure myself as I have not run them.
https://linustechtips.com/topic/1398183-micron-ram-max-voltage/#findComment-15169715
