Hi, this is my first time on the forums, and i had a question.
I have a 620 watt antec power supply, and i was wondering if i had enough power to overclock my processor and graphics card.
I7 4770k - want to overclock to hopefully 4.7 ghz
Xfx r9 290 - want to overclock to 1400 MHz
8 gb of corsair vengeance ram
Asus z87 gryphon motherboard
Antec high current gamer 620 watt psu
https://linustechtips.com/topic/139784-enough-power-to-overclock/
you should have enough power for both of them to be overclocked
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
620W of 80+ Bronze power is excessive even for an overclocked 4770K and an R9 290
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
That's more than enough power. You'll definitely want an aftermarket cooler for the CPU if you don't have one already. Also, from what I've seen, the R9 290 doesn't overclock very well, so you'll be very lucky if you can get it to run at 1400MHz. Even 780s and 780Tis that overclock very well won't run at 1400MHz and be stable.
