Hello!
I'm planning to build and mini-itx pc using some old parts. I'm planning to use:
PSU: Corsair RM Series RM650 (2019)
CASE: Jonsbo V10
The case lists Power Supply: ATX≤150MM, SFX/SFX-L and the PSU 160mm. Has anyone tried this or know this case to know if this is possible or a no go?
best regards
https://linustechtips.com/topic/1396513-will-it-fit-the-case/
You should be able to find PSU dimensions on corsair's website. Alternatively, you could measure it if you have it on hand. I'm seeing ATX no greater than 150mm or a SFX/SFX-L. If your PSU is 160mm you're out of luck, it seems.
Salisbury steak isn't steak.
https://linustechtips.com/topic/1396513-will-it-fit-the-case/#findComment-15158626
