so i have an older gpu radeon r9 270x and i had problems with one fan so i replaced it with new one and then soldered it to the old cables, then plugged i in turned on and i saw sparks coming from there so i quickly turned it off. When i booted it up again it turned on it seems like working but the fans are not spinning so i plugged it out. It was probably my fault in isolating the cables but is there any way to fix this? i dont want to break it more
thanks
https://linustechtips.com/topic/1394745-gpu-fan-short-circuit/
