Hello everybody!
Today, as I pressed the start button on my PC, all the lights and fans turned on as usual but than suddenly (after 1 second or so...) it turned off. I pressed the start button again and the PC ran as usual but one fan is not spinning. It is an RGB fan and the lights are working, it is just not spinning. One maybe important information: after I pressed the start button for the first time, I plugged my keyboard in the front usb panel, as I am working on home office now and sharing the peripherals on both my working laptop and home PC.
So my question is, is the fan dead? What could be the reason for that? Is it dangerous to run the PC until I fix it (most probably replace the fan)?
Thanks a lot!
Matej
https://linustechtips.com/topic/1392642-fan-stopped-working/
4 minutes ago, matejbobo said:
is the fan dead?
First of all, you can check if it's still connected. You can try to unplug it and plug it back in.
I don't know if it's dead, but you can find out. You can check the fan at a different fan connector or swap it with a working one.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
https://linustechtips.com/topic/1392642-fan-stopped-working/#findComment-15132186
