Help with Ram slot distribution
I had 2 kingstone hyperX 8gb ddr 4 ram sticks and I bought 2 new kingstone beast 16gb ddr 4 sticks.
The PC works if I slot the 2 16gbs in slot 2 and 4, but wont work if I add the 8's to slot 1 and 3, the lab I bought from said they should work togather.
Do I need to slot the 16's in 1 and 3 and if so does it hurt performance?
Clear the cmos while you are installing the memory and try again.
It sometimes helps if you slot each kit into a single channel. You hopefully had the original kit distributed across both channels, so you would need to move one of the original sticks.
Zen+ isn't known for having the strongest IMC, so it's possible it's just not going to like having all 4 slots populated. When buying an additional kit of RAM to add to an existing one, you're far better off getting the exact same kit again. You're mixing two entirely different kits, so there's definitely more potential for issues. You may need to tweak the frequency, timings, and voltages manually to get it stable.
CPU: AMD Ryzen 9 5900X · Cooler: Artic Liquid Freezer II 280 · Motherboard: MSI MEG X570 Unify · RAM: G.skill Ripjaws V 2x16GB 3600MHz CL16 (2Rx8) · Graphics Card: ASUS GeForce RTX 3060 Ti TUF Gaming · Boot Drive: 500GB WD Black SN750 M.2 NVMe SSD · Game Drive: 2TB Crucial MX500 SATA SSD · PSU: Corsair White RM850x 850W 80+ Gold · Case: Corsair 4000D Airflow · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: Corsair K100 RGB Optical-Mechanical Gaming Keyboard (OPX Switch) · Mouse: Corsair Ironclaw RGB Wireless Gaming Mouse
