Helloo!
So, im building a gaming pc in a Corsair 380T, with a Asus ROG B560-I Mobo. I was planning to fit a GTX 1080 Ti in it, and found an Aorus xtreme for a reasonable price (500$). My only concern is that the max GPU length for this Case is officially 290mm, and 1080 Aorus is 293mm long!
Will it be possible to fit the GPU?
To find out we recreated this build in PC Build Simulator and it looks like there should be enough space to fit the GPU.
I feel like 3mm can't possibly be that big of a problem, right?
https://linustechtips.com/topic/1388274-does-3mm-matter-for-fitting-a-gpu/
5 minutes ago, Shroobs said:
Helloo!
If it wont fit it wont fit.
simulators arent that good, that moustly have a hit box problem, or they allow that kind of interference between two parts, so if u can kinda borrow the gpu and try to fit it, but in my opinion it can actually make a lot of problems, u may gonna fit it but the socket on the motherboard could be under a lot of tension because the case is gonna try to push the gpu out, but it also could be that the case is gonna just bend and ur gonna be fine
Thx, will keep this in mind when i build it. Just found a post about someone who measured the ACTUAL max GPU length for the case, the result showing 297mm.
