Hey guys need some help with P.C parts for my new rig :). My pice tag would be no more than $1000 but I only need a CPU, Motherboard, Graphics card, Power supply and would like a SSD too just to put O.S and maybe some games (120gb). With the Graphics card i would really like to say on the Nivida side of things because  I think i would utilize the video recorder a lot more than anything on the AMD side and also forgot to mention I would like to play at 1080p. Thanks for the help :)
https://linustechtips.com/topic/138815-need-help/
location? os? peripherals?
Specs
https://linustechtips.com/topic/138815-need-help/#findComment-1850748
Location=Australia, O.S=Windows 7 and Peripherals= don't need anything to do with peripherals if thats what you are asking
use the quote button it gives me a message if you cant afford the extra 100 quote me and ill change some stuff
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  ($189.00 @ PCCaseGear)
Motherboard:  Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard  ($179.00 @ PCCaseGear)
Memory:  Kingston Beast 8GB (2 x 4GB) DDR3-1600 Memory  ($109.00 @ Mwave Australia)
Video Card:  EVGA GeForce GTX 760 2GB Video Card  ($319.00 @ PCCaseGear)
Case:  Cooler Master N600 Windowed ATX Mid Tower Case  ($99.00 @ CPL Online)
Power Supply:  Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($105.00 @ Mwave Australia)
Operating System:  Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($115.00 @ Mwave Australia)
Total: $1183.00
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-04-12 17:58 EST+1000)
Specs
https://linustechtips.com/topic/138815-need-help/#findComment-1850774
Total: $1183.00
wow thanks soo much and don't worry about the O.S forgot to mention that I already got a copy of windows 7(don't ask where I got it from)
(p.s sory about the quote thing I think you can tell that I'm about of a new a nebie around here ;))
https://linustechtips.com/topic/138815-need-help/#findComment-1850781
na its fine no one expects you to know everything :P but if you already have windows it should be pretty much on your budget
Specs
https://linustechtips.com/topic/138815-need-help/#findComment-1850786
One thing I promise I don't need ram, case or hard drive is anyting you would change sorry for being annoying :(
so case storage and memory well here you go just make sure you have 8gb ram because you need that much for gaming
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  ($189.00 @ CPL Online)
CPU Cooler:  Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($39.00 @ Mwave Australia)
Video Card:  EVGA GeForce GTX 770 2GB Video Card  ($429.00 @ PCCaseGear)
Total: $941.00
(Generated by PCPartPicker 2014-04-12 18:26 EST+1000)
Specs
https://linustechtips.com/topic/138815-need-help/#findComment-1850840
Total: $941.00
Thanks agiain and yes I've got 8gb og corsair vegence blue memory thanks :)
https://linustechtips.com/topic/138815-need-help/#findComment-1850848
