Budget : $5000 USD
Country: USA
Games, programs or workloads that it will be used for: Unreal Engine 5 for game development, graphic arts from multiple programs, motion capture, video animations, gaming (i don't need to play on highest settings but, it would be nice if I can test my own creations in 4k)
Other details:  I tried piecing together some things I think would allow me to work efficiently and be quiet enough to not interfere with voice recording in the same room. Thus the "be quiet" choices that may or may not have enough space for everything. I'm struggling whether or not to bite the bullet on overpriced graphics right now. No one can predict when the price will go down but, it certainly makes my stomach hurt paying 2-3x MSRP.
I only need to run 1 monitor but if I can run 2, why not? I can be very patient time wise and will probabaly try to clutch some black Friday/cyber Monday deals. I can wait longer if it makes sense to save more.
My friends say I should consider a threadripper CPU I just don't know if that's overkill? I want high end but I don't want to max my budget for little performance increase.
PCPartPicker Part List: https://pcpartpicker.com/list/mf6QTJ
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor ($559.99 @ Newegg)
CPU Cooler: ARCTIC Liquid Freezer II 240 56.3 CFM Liquid CPU Cooler ($86.99 @ Amazon)
Motherboard: Asus ROG Crosshair VIII Hero (WI-FI) ATX AM4 Motherboard ($389.99 @ Newegg)
Memory: G.Skill Ripjaws V 64 GB (2 x 32 GB) DDR4-3600 CL18 Memory ($278.99 @ Newegg)
Storage: Samsung 970 EVO Plus 2 TB M.2-2280 NVME Solid State Drive ($238.79 @ Amazon)
Video Card: ASRock Radeon RX 6800 XT 16 GB Phantom Gaming D OC Video Card ($1409.98 @ Newegg)
Case: be quiet! Dark Base 700 ATX Mid Tower Case ($174.90 @ Newegg Sellers)
Power Supply: be quiet! Straight Power 11 850 W 80+ Platinum Certified Fully Modular ATX Power Supply ($174.90 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($108.78 @ Other World Computing)
Total: $3423.31
Generated by PCPartPicker 2021-10-25 13:57 EDT-0400
https://linustechtips.com/topic/1383811-unreal-engine-5/
I believe the RM850X (2018) or (2019) is a quieter PSU.
DDR4-3600 CL16 should offer marginally better performance, especially in renders.
Personally, I would get a less expensive motherboard like the MSI MAG X570 TOMAHAWK WIFI. I'd also go for a smaller case, something like the Meshify 2 Compact.
https://linustechtips.com/topic/1383811-unreal-engine-5/#findComment-15066671
So I am looking up the parts you've mentioned, the motherboard is still compatible and cheaper which is cool.
The power supply is extremely popular with over 8000 reviews. A surprising number of them appear to be duds though. Either it works great forever or it catches things on fire hahaha. I might need to poke around some more to see if they just got from a bad supplier.
Thank you for pointing out the CL16. I will dig into finding low latency ram.
https://linustechtips.com/topic/1383811-unreal-engine-5/#findComment-15067015
It is probably the most popular PSU so no surprise there appears to be more complaints. Also check dates. The initial rmx offering (pre 2018 if I recall correctly) definitely had a lot of issues. The 2021 is also getting very good reviews but is a touch louder.
https://linustechtips.com/topic/1383811-unreal-engine-5/#findComment-15067168
