Budget (including currency): >$1000
Country: United States
Games, programs or workloads that it will be used for: Destiny, Fallout, Call of Duty and possibly running VMs
Other details Attached is a picture of possible parts for my first PC build.May or may not use the included cooler for the 5600X (ignore 2nd cooler, added by mistake) and I already have a GTX980ti graphics card. Any thoughts or suggestions  or thoughts on the parts being my first build?
Edit: GTX 980Ti not RTX and part picker link: https://pcpartpicker.com/user/Spooky_Jose/saved/CTYn6h
thank you for your time!
jose
https://linustechtips.com/topic/1382655-first-pc-builds/
7 minutes ago, Spooky_Jose said:
RTX980ti
There is nothing such like that
There is only gtx980ti
The only Geforce RTX series GPUs are as follows:
Geforce RTX 2060
Geforce RTX 2060 super
Geforce RTX 2070
Geforce RTX 2070ti
Geforce RTX 2070 super
Geforce RTX 2080
Geforce RTX 2080ti
Geforce RTX 2080 super
Geforce RTX 3060
Geforce RTX 3060ti
Geforce RTX 3070
Geforce RTX 3070ti
Geforce RTX 3080
Geforce RTX 3080ti
Geforce RTX 3090
for your budget a 60 and 70 series GPU is good if you want ray tracing
but going gtx can save you money
Pls Mark a solution as a solution, would be really helpful.
BTW pls correct me, iam really stoobid at times.
https://linustechtips.com/topic/1382655-first-pc-builds/#findComment-15058235
Other details Attached is a picture of possible parts for my first PC build.May or may not use the included cooler for the 5600X (ignore 2nd cooler, added by mistake) and I already have a RTX980ti graphics card. Any thoughts or suggestions  or thoughts on the parts being my first build?
jose
please send pc part picker link
hard to see the parts
https://linustechtips.com/topic/1382655-first-pc-builds/#findComment-15058236
Geforce RTX 2060
Geforce RTX 2070
Geforce RTX 2070ti
Geforce RTX 2080
Geforce RTX 2080ti
Geforce RTX 3060
Geforce RTX 3060ti
Geforce RTX 3070
Geforce RTX 3070ti
Geforce RTX 3080
Geforce RTX 3080ti
Geforce RTX 3090
Thanks for catching that yes it’s GTX! Yea it was given to me from a friend so just happy I got one!
https://linustechtips.com/topic/1382655-first-pc-builds/#findComment-15058282
Sorry about that here is the link with the specific card I have as well!
https://linustechtips.com/topic/1382655-first-pc-builds/#findComment-15058284
ok good!!
now can you send me the pc part picker link
pls it is so hard to see from the photo
Edited by my name is guru iam tech
iam sorry did not saw the post don't be confused
https://linustechtips.com/topic/1382655-first-pc-builds/#findComment-15058286
umm the list is private
iam not able to see it
https://linustechtips.com/topic/1382655-first-pc-builds/#findComment-15058289
ok good!!
Yea I realized haha my bad! I added to my post, but here you go just in case!
Second time is the charm should be public now
Edited by Spooky_Jose
https://linustechtips.com/topic/1382655-first-pc-builds/#findComment-15058290
the PSU is a legit firehazard, the MSI 750w A-GF is cheaper and much better.
https://linustechtips.com/topic/1382655-first-pc-builds/#findComment-15058317
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($299.99 @ B&H)
CPU Cooler: Thermalright Frost Spirit 140 77.8 CFM CPU Cooler  ($45.56 @ Amazon)
Motherboard: MSI MPG B550 GAMING PLUS ATX AM4 Motherboard  ($144.99 @ Amazon)
Memory: Crucial Ballistix RGB 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory  ($89.99 @ Adorama)
Storage: Silicon Power P34A80 1 TB M.2-2280 NVME Solid State Drive  ($94.99 @ Amazon)
Video Card: EVGA GeForce GTX 980 Ti 6 GB Superclocked+ ACX 2.0+ Video Card
Case: Phanteks Eclipse P400A Digital ATX Mid Tower Case  ($89.99 @ Amazon)
Power Supply: MSI MPG A-GF 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Amazon)
Total: $855.50
Generated by PCPartPicker 2021-10-20 23:25 EDT-0400
https://linustechtips.com/topic/1382655-first-pc-builds/#findComment-15058323
