Need some help
Solved by Dr0idGh0sT,
3060 ti would be better card.
If you don't care about RGB, Tell them you don't want it, Non RGB parts are mostly cheaper and it should bring your cost down.
Also, You don't want X570 motherboard, Get cheaper one, Such as MSI B550A-Pro, That also saves some money.
And last thing, Samsung 980 is expensive, But not good performing drive. I don't know availability in your country, But Crucial P5, WD SN750, HP EX920, Muskin pilot-e are better drives and lower price, So also recommend changing SSD and get 2TB HDD, It should be only around ~20 USD more.
