Budget (including currency): N/A
Country: UK
Games, programs or workloads that it will be used for: N/A
Hi guys so i have completed all the tubing get for my custom waterloop. I tested it for leaks with the EK leak tester and everything was fine. However i have an issue the pump not pumping enough its defintiely going but just barely. The waterlevel cant even get above the first radiator
The loop consists of:
Top and Bottom Radiator: EK Coolstream XE 360
2 Bitspower GPU blocks
EKWB Hero Monoblock
I've added a video to show whats going on with the water
https://linustechtips.com/topic/1378585-custom-waterloop-issue/
2 minutes ago, tkitch said:
you may need to assist getting the air out of the tubing.  Once the loop is complete, gravity helps the water move better.
Cool will figure out best way to shake it around to get the air out lol bloody heavy even without so much water in lol
https://linustechtips.com/topic/1378585-custom-waterloop-issue/#findComment-15028950
