I am getting some new parts for my pc And it will consist of a fx8120, a HIS IceQ 7870, a xigmatek dark knight 2, a msi 970a g46, and it will have about 6 fans including the heatsink fans. What power supply should I get, I am going to be overclocking and I would like something something blue if possible
https://linustechtips.com/topic/13780-good-power-supply/
Do you want modular, semi modular, or non-modular? Maybe a Seasonic Platinum-660 if your looking to expand a lot in the future and since it goes on sale quite often (it has went down $90 3 times in the past months). Head over to http://www.reddit.com/r/buildapcsales to find sales on all type of parts and just keep your head up for power supplies.
https://linustechtips.com/topic/13780-good-power-supply/#findComment-149915
I would recommend a Corsair GS600, which is an attractive Blue power supply which would supply ample power. It also has LEDs which can be turned off or on, all at an attractive price point. You can buy them for around $80, or £55. You can buy them for around $80, or £55.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139045&Tpk=gs600&IsVirtualParent=1
http://www.corsair.com/us/power-supply-units/gs-series-power-supply-units/gs-series-gs600-80-plus-bronze-certified-power-supply-2013-edition.html
Fractal Design Define R4 | Intel i7-4770K | Corsair H80i | Corsair SP120 PWM | MSI Z87-GD65 GAMING | 8GB Corsair Vengeance Pro | MSI GTX770 GAMING | Samsung 840EVO 120GB | 2x WD Red 2TB | Corsair AX760 | Windows 8 Pro
https://linustechtips.com/topic/13780-good-power-supply/#findComment-149983
Good suggestions.  Also, my preference is always for semi-modular.  Reason being that having the Motherboard & CPU cable fixed makes it easier to channel when you're going from the PSU and out through the cable management.  The modular cables are hard to wrangle the first couple of inches as they come out of the PSU.
My Stuff:  Corsair Obisidan 550D - Phobya Nano-2G 120mm x 5 - Corsair H100i - MSI Z77A-GD65 Gaming - Intel 3570K - G.Skill 8GBx2 1866 - EVGA ACX GTX 780 3GB SuperClocked(Step Up to 780 Ti) - Samsung 840 500GB SSD - WD Black 1TB x 2 - LG Blu-ray - ASUS VG248QE + ASUS PB278Q - Corsair M65 with MM400 Pad - Ducky Shine II MX Brown with Gray/White Keycaps - Corsair K70 MX Red - CoolerMaster Quickfire TK MX Brown - Ducky Pro2 MX Blue with Gray PBT Keycaps - Ducky Pro2 MX Clears with Gray/Blue PBT Keycaps - Ducky Pro2 MX Browns with Light Gray and White PBT Keycaps
https://linustechtips.com/topic/13780-good-power-supply/#findComment-150026
