This program is designed to count how many vowels are in the words the user input, and the program ends when the user does CNTR+D. For some reason the last time the loop runs it always adds the last found vowel a second time.
So you would enter 'a' and it would say there were 2 of them.
#include <stdio.h>
#include <string.h>
int main(){
    // Creates string variable to store the users input
    char userString[64];
    // Prompts user for a string
    printf("Please enter a string that is all lowercase and less than 50 charecters\n");
    // Creates variables to store the number of each vowel in the string
    int numA = 0;
    int numE = 0;
    int numI = 0;
    int numO = 0;
    int numU = 0;
    // While loop to count how many of each vowel(s) are in the lowercase string
    while(1) {
        // Ends the program when the user enters CTRL+D
        if (feof(stdin)) break;
        // Stores the user input in userString
        scanf("%s", userString);
        for (int i = 0; userString[i] != '\0'; i++) {
            // Adds the 1 to the total number of each vowel when the vowel comes up in the string
            if (userString[i] == 'a') {
                numA += 1;
            else if (userString[i] == 'e') {
                numE += 1;
            else if (userString[i] == 'i') {
                numI += 1;
            else if (userString[i] == 'o') {
                numO += 1;
            else if (userString[i] == 'u') {
                numU += 1;
    // Prints the output for the number of each vowel in the string
    printf("The vowel a occurred %d times\n", numA);
    printf("The vowel e occurred %d times\n", numE);
    printf("The vowel i occurred %d times\n", numI);
    printf("The vowel o occurred %d times\n", numO);
    printf("The vowel u occurred %d times\n", numU);
    // Returns a 0 to end the program
    return 0;
https://linustechtips.com/topic/1375002-weird-behavior-in-c-for-loop/
I'm not super well versed in some of the C stdio functions, but if you flip the positions of the ctrl-D check and parsing for text, it will return the correct values (per my simulations).
EDIT: Here's what I assume is happening in the loop...
  1. Ctrl-D is checked for
  2. String is parsed
  3. String is counted
However, by the time you can enter ctrl-D, the program is already blocking on the "string is parsed" line, so it has to loop through again before the ctrl-D check, and I assume that a ctrl-D input to the parse function doesn't fully overwrite what was in the buffer, so (most of?) it gets counted again. If you do it the other way around (as I suggest), you parse input, then check if it happens to be ctrl-D before continuing to count.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
11 minutes ago, AbydosOne said:
However, by the time you can enter ctrl-D, the program is already on the "string is parsed" line, so it has to loop through again before the ctrl-D check,
Precisely this. At the beginning of loop #2, the EOF check fails, and scanf() gets called. scanf() encounters EOF, and returns without doing anything to userString. The loop continues, and parses userString again. At the beginning of loop #3, the EOF check passes, and the while loop breaks.
Instead of a while(true) loop, this should be the conditional check:
while(scanf("%s", userString) != EOF)
I was able to fix it by doing this
    while(1) {
        if (feof(stdin)) {
            break;
Essentially just had to switch it so the scanf is before the feof(stdin) statement.
