it depend what you are putting in the case, are you water cooling, air cooling, are your getting a modular psu.
if you are going with air cooling and a non modular psu get the one with the most room behind the back panel to hide all those cables to keep airflow optimized.
CPU: i7 3770k 4.5ghz M/Board: Sabertooth Z77 GPU: Asus Gtx 560 Direct CUii OC RAM: 2x4gb Corsair Veangance PSU: Corsair CX600 Cooler: Custome Water Loop With Gentle typhoon 1850rpm fan, Single 120mm Rad, XSPC Raystorm CPU Block
https://linustechtips.com/topic/13727-going-to-build-a-pc/#findComment-149132
Comparing the two choices you game me, I prefer the 650D. The 650D is a better built product and will result in better observable-performance due to better airflow when compared to the 600T. However, I suggest the 350D or the 900D depending on your application, if these two suggested products are within your budget and Corsair seems to be your company of choice.
https://linustechtips.com/topic/13727-going-to-build-a-pc/#findComment-149232
