I built my first pc and i have some question
Solved by SimplyChunk,
10 minutes ago, ysssss said:
If you're not having problems then don't worry about it. Quite often PC hardware will have random headers or sockets on them that have no purpose other than diagnosis and testing in factory.
Just looked again and it looks like a 'mode' switch. It's for hooking up a momentary switch to change the RGB modes of the fans. If your case doesn't have a dedicated bitton for RGB you could hook the reset switch up to it for mode switching
