I've ordered A computer with a b550-f Asus Rog strix motherboard, ryzen 5900x, pcie gen 4 nvme and a 3060 graphics card.  As I understand it this should all be fine, however I have a little confusion over how the pcie lanes work on this board as I think only the top gpu slot uses 4.0 which is fine for my purposes but is it possible to use a second graphics card(1050ti), second (this time gen 3) nvme and a wireless adapter card  as well or is there not enough lanes to support this? If anyone has any advice or comments on this it would be much appreciated
https://linustechtips.com/topic/1370302-pcie-lane-help/
im not sure how it goes but someone can correct me that if you have more than 1 pcie card itll lower the bandwith and split it be tween eachother meaning instead of you;re gpu having x16 itll have x8 lanes which if you were gaming it would lower the fps quite a bit
Main:
  • CPU
    10700k 5ghz All core 47 ring ratio 1.275v
  • Motherboard
    MSI Z590 A Pro
  • RAM
    4x8 viper steel samsung bdie: 4200-17-17-30
  • GPU
    Gigabyte RTX 3080 Gaming Oc
  • Case
    O11 air mini
  • Storage
    970 Evo Plus 500gb OS, Sn550 1tb, 860 evo 500gb, 2tb MX500
  • PSU
    RM750x (2018)
  • Display(s)
    Acer Nitro vg272up, Kogan 24 1080 120hz
  • Cooling
    arctic 280aio, EK M.2 NVMe Heatsink on 970 evo plus
    Second:
    Cpu: i5-8400
    Cooling: ID-Cooling Frostflow 120x
    Ram: 2x8gb 2666 c16 hyperx fury, tuned the absolute balls out of it but def not stehble.
    Mobo: Asus Prime H310M-K
    Gpu: Igpu
    Case: Coolermaster MB311L
https://linustechtips.com/topic/1370302-pcie-lane-help/#findComment-14969109
It's fine for the 3060 as it only needs 8*pcie gen4, the issue is that I'm not sure if it does split to the second slot or not on this particular motherboard -and if it doesn't whether it has enough chipset lanes to do what I want
https://linustechtips.com/topic/1370302-pcie-lane-help/#findComment-14969113
your mobo will support that
Main:
  • CPU
  • Motherboard
    MSI Z590 A Pro
  • RAM
  • GPU
  • Case
    O11 air mini
  • Storage
  • PSU
    RM750x (2018)
  • Display(s)
  • Cooling
    Second:
    Cpu: i5-8400
    Gpu: Igpu
https://linustechtips.com/topic/1370302-pcie-lane-help/#findComment-14969117
7 minutes ago, AdiUwU said:
Only one of the pcie slots supports gen 4 so I'm honestly not certain that it does on this occasion
actually you're mobos gen 4 x16 slot is used by cpu and the other 2 3rd gen is powered by the mobo chipset so you can use full gen 4 x16 on you're gpu and split the 1050 ti and wifi card with the mobo
Main:
  • CPU
  • Motherboard
    MSI Z590 A Pro
  • RAM
  • GPU
  • Case
    O11 air mini
  • Storage
  • PSU
    RM750x (2018)
  • Display(s)
  • Cooling
    Second:
    Cpu: i5-8400
    Gpu: Igpu
https://linustechtips.com/topic/1370302-pcie-lane-help/#findComment-14969130
