PC Part Questions
Solved by Somerandomtechyboi,
2 minutes ago, RaphCode said:Would it affect my upgradeability in the future for a better gpu
No, you can just stick a gpu in your system and itll work fine, the cpu prob wont bottleneck you since its a zen 3 cpu, or was it a zen 2 cpu? Idk
4 minutes ago, RaphCode said:The msi mpg 850w version is $149, should i get this one instead or no
Yes
4 minutes ago, RaphCode said:And previously asked, from the 275r airflow, 4000D and 4000D airflow, which one would be the best out of those 3?
Eh they are all good, though id go for the cheapest among those 3
