If this is the wrong place for this, let me know or move it where it should go.
I've been running a small Ark server for about a year now but no matter what I do, I can't get any one to connect to it unless we use LogMeIn from Hamachi.  I had another friend try hosting a server from his actual server and no one can connect with out using Hamachi.  People can connect inside my home network, but my friend 150 miles away can't unless we use Hamachi.  Does any one here know how to fix this or know why this is happening.  We're all using the steam version of the game and server.
https://linustechtips.com/topic/1364575-ark-survival-evolved-connection-issues/
They cant connect because theres no "pathway" to it.
If you're on CGNAT (your public IP is shared) then you're out of luck, and need to talk to your ISP.
If you have a dedicated IP address (it could be static or dynamic), then you need to forward the port in your router.
Your router needs to take the incoming requests and direct them to the server that is hosting your ARK server.
A quick look it appears you need UDP Port 27015 (query port) and UDP Port 7777 (game port) at the very least.
So you need to make sure you have a static IP address assigned to your server and forward the ports to it in your router.
This site has good step by step guides on how to setup port forward: https://portforward.com/router.htm
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
