Interesting Issue
On 8/9/2021 at 9:11 AM, bailz123 said:My thermals seem normal, do you have any clue as to what it could be seeing as turning my monitor off and on generally turns it back to normal? I've never heard of anyone else ever having this issue, or maybe they just don't notice it as much as I do? I've had two of these monitors and I'm certain I've had the same weird issue occur with both
So judging from the 'turning my monitor off and on generally turns it back to normal', it seems to be a monitor issue? Because, (conflicting information online, it seems to depend on device聽but general verdict seems to be聽that) video signal is still outputted even when your monitor is powered off manually. I would say try another monitor, but you did so
聽maybe try another model?
Dirty power or EMI might cause the issue (however rare it is) so to confirm, EVERY time you have extended periods of gaming, you encounter this issue? And always after extended gaming periods?聽
Note that I havent had experience with this kind of issue before (both possibilities EMI and monitor [because it doesn't seem to be a common bug at all]). So take my advice with a grain of salt.
聽
