Surface Book Screen Battery Not Working
Solved by markwoll,
Given the age of the device and experience with lots of surface pro 3 & 4 with bad batteries ( swelling, not holding charge ) I would back up your data and reset the unit.
There were issues with some firmware and surface pro 3 ( not the laptop, but similar enough ) and battery life.
Resets fixed the problem on at least one. There is an option to keep files, it will break non MS applications though.
There are a number of potential solutions in this thread. Perhaps one of the less drastic ones ( contact cleaning, bios option changes, etc ) can help before a factory reset.
