I purchased a known working evga 1050 ti sc from a friend but cant get it working in my system. I have tried:
- deleting old graphics driver
- verifying bios are current
- verifying bios set to pcie1
All I get is a blank screen (monitor turns off when no signal detected but it is on and has visible backlight, just blank)
Specs:
Mb, Gigabyte ga-970a-ds3p
Cpu, amd fx 4350
Old gpu evga gtx 660
1tb samsung 980 storage and wb 512gb boot sad
700w power supply
16gb ddr3 memory
No  integrated graphics so i cant run anything without functioning card. thanks in advance
https://linustechtips.com/topic/1362744-help/
And your old system works with the GTX 660? The only thing that's different is swapping out the graphics card?
It's entirely possible that I misinterpreted/misread your topic and/or question. This happens more often than I care to admit. Apologies in advance.
珠江 (Pearl River): CPU: Intel i7-12700K (8p4e/20t); Motherboard: ASUS TUF Gaming Plus Z690 WiFi; RAM: G.Skill TridentZ RGB 32GB (2x16GB) DDR4 @3200MHz CL16; Cooling Solution: NZXT Kraken Z53 240mm AIO, w/ 2x Lian Li ST120 RGB Fans; GPU: EVGA Nvidia GeForce RTX 3080 10GB FTW3 Ultra; Storage: Samsung 980 Pro, 1TB; Samsung 970 EVO, 1TB; Crucial MX500, 2TB; PSU: Corsair RM850x; Case: Lian Li Lancool II Mesh RGB, Black; Display(s): Primary: ASUS ROG Swift PG279QM (1440p 27" 240 Hz); Secondary: Acer Predator XB1 XB241H bmipr (1080p 24" 144 Hz, 165 Hz OC); Case Fans: 1x Lian Li ST120 RGB Fan, 3x stock RGB fans; Capture Card: Elgato HD60 Pro
翻生 (Resurrection): CPU: 2x Intel Xeon E5-2620 v2; Motherboard: ASUS Z9PR-D12 (C602 chipset) SSI-EEB; RAM: Crucial 32GB (8x4GB) DDR3 ECC RAM; Cooling Solution: 2x Cooler Master Hyper 212 EVO; GPU: ASRock Intel ARC A380 Challenger ITX; StorageCrucial MX500, 500GB; PSU: Super Flower Leadex III 750W; Case: Phanteks Enthoo Pro; Expansion Card: TP-Link Archer T4E AC1200 PCIe Wi-Fi Adapter Display(s): Dell P2214HB (1080p 22" 60 Hz)
壯麗 (Glorious): Mainboard: Framework Mainboard w/ Intel Core i5-1135G7; RAM: G.Skill Ripjaws 32GB (2x16GB) DDR4 SODIMM @3200MHz CL22; eGPU: Razer Core X eGPU Enclosure w/ (between GPUs at the moment); Storage: Samsung 970 EVO Plus, 1TB; Display(s): Internal Display: Framework Display; External Display: Acer (unknown model) (1080p, 21" 75 Hz)
https://linustechtips.com/topic/1362744-help/#findComment-14918500
Ct, yes the 660 works fine and its a basic swap out and in. The displays backlight is on so it's gotta be doing something otherwise my monitor would turn off as part of energy saving mode. Bhameck, there is not a 6 pin connector on the evga 1050ti sc ive checked like 1000 times. Its driving me crazy as it should be a simple swap
https://linustechtips.com/topic/1362744-help/#findComment-14919530
