Problem with Hyperx Quadcast Mic
Solved by danalog,
It’s def a grounding issue. Is that a USB mic or XLR? I would assume the mic grounds to the casing and there’s something quite wrong with the voltage converter. To explain, I assume it’s USB, many mics need what’s called phantom power, especially cardioid condenser mica like that. For xlr it’s over the cable, but for usb power there’s an internal chip that steps it up from 5 volts to 48. Seems like you’re getting 48 volts 2 amps straight to the finger. Ask hyperx if you can get it replaced bc that’s a legit problem that’s not your fault.
